Why does part in exploded view explode at angle?
Vagulus
Vagulus
I have an exploded presentation of a valve
As you can see, the retainer above the left-hand ball has exploded at an angle.
Why?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Sergio.D.Suárez
the imate of part AE-006-0009 is in the assembly related to axis and point, it is convenient in cylinders that this axis with axis. Notice that there is an angle of 2.36 g of phase shift so when you make the ipn the angle is more noticeable
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
blandb
Your retainer is constrained crooked:
So, by leaving the UCS to local, the arrow will move in relation to the UCS of the part. If the UCS in the tweek is set to "World" it becomes square with the assy UCS. But due to the retainer being skewed, it still comes out as skewed.
Hope that makes sense.
Autodesk Certified Professional
Vagulus
Thanks to both of you.
Silly me.
I should have figured that out.
Albert Einstein
