iLogic tutorial
iLogic tutorial
Message 1 of 10
iLogic tutorial
Hi!
          Can someone recommend a good iLogic tutorial?
Thanks!
Replies (9)
Message 2 of 10
johnsonshiue
Hi! You can do a quick search on the forum and Autodesk Knowledge Network. Also, there are some books about Inventor iLogic available for purchase at Amazon.com.
From my limited experience, iLogic is best learned by using it. At the very beginning, it may look a bit overwhelming if you are not a programmer. But, the concept is very straight forward. Once you get past the initial shock, you will find many use cases allowing you to customize your workflows.
Let's start from the basics. On top of your head, can you think of something you would like to customize or automate? There usually should be a solution in iLogic.
Many thanks!
Software Test Engineer
Message 3 of 10
jtylerbc
I second @johnsonshiue's suggestion.  You may very well be able to find some tutorials that will help you get started, but you'll learn most of it by experience using it.
I'm a terrible programmer, but I use iLogic all the time.  The sample snippets in the editor will take you a long way, even without knowing much about programming.  Obviously you can do more in-depth automation with more programming skill and knowledge of Inventor's API, but you can accomplish a lot just by poking around and trying things.
I would suggest coming up with some simple scenario and trying to automate it using combinations of the sample snippets.  It doesn't have to be something from your real application, or even anything with practical value.  For example:
  1. Extrude a box.
  2. Name the extrusion distance "Length".
  3. Set the part's appearance to "Dark Green".
  4. Write a simple (maybe a little silly) iLogic rule that changes the appearance to "Red" if the Length parameter is greater than some limit you choose, and otherwise changes it back to "Dark Green".
This should be doable by inserting an "If / Then / Else" structure and looking around through the snippets to figure out how to control the part color.  You'll probably learn a lot about what you can control with iLogic just in the process of looking for the snippets to build a few simple practice rules like this.
Message 4 of 10
@jtylerbc and @johnsonshiue
Thanks for your replies!
Message 5 of 10
S_May
Message 6 of 10
leowarren34
It's long but I found this helps: https://www.youtube.com/watch?v=xGx8hXKaYu8
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 7 of 10
Thanks for all your replies!
Message 8 of 10
What is the programming language name for scripts in iLogic?
Thanks!
Message 9 of 10
Is it Visual Basic (VB.NET) ?
Am I right?
Message 10 of 10
Skadborg.NTI
Yes, it is VB.NET with some additional stuff on top. You can use the full potential of VB.NET like database access, filehandling, interacting with other programs etc.
