Why does my assembly drawing become faded after exporting it as a pdf file?
szelanna2000
szelanna2000
How can I export my drawing without it becoming faded? I know that it's probably because it's in raster view, but if I make it precise then it removes all the edges and lines that I would like to show on my exported drawing aswell.
Gabriel_Watson
Have you tried these two options?
You could also try to go to your layers and activate "Automatic" under Appearance color:
-niels-
Don't use raster view and turn on "tangent edges" for the lines you're "missing"?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
sam4JPGY
Community Visitor
Community Visitor
This is the answer
ldutkaTUZ58
That first "PDF" box is visible when you select the "Export" box, then the PDF selection.
ldutkaTUZ58
The second box is under "Annotate" tab in the drawings (.idw), then to the far right, the "Edit Layers". Hoping this will be easier for the newbies and experienced alike to locate these features mentioned.
