Why does Inventor not update?
Laurens-3DTechDraw
Mentor Mentor
Message 1 of 16
Laurens-3DTechDraw
Picture says it all I guess.
I just downloaded the SP1 file since that didn't go automatically either.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Replies (15)
Message 2 of 16
blair
I zoomed my browser to 400% and still couldn't make out what your issue is from the pictures you posted.
Delta Tau Chi ΔΤΧ
Message 3 of 16
JDMather
Use the Window Snipping tool
or
Alt Print Screen to capture active dialog box to the clipboard.
Post 3 separate images.
Message 4 of 16
Curtis_Waguespack
@blair you can right click the image and choose Save Picture As, and it will download it in the orignal size, which can then be opened in your image viewer on your system as full scale.
@Laurens-3DTechDraw unfortunately, even after downloading your image and looking at the screen shots, I'm still not sure what question you were intending to ask. Can you provide more details? (also, if you press ALT + PRTSCN you can take a screen capture of just the active window.
I hope this helps.
Curtis
Message 5 of 16
Laurens-3DTechDraw
My problem is, why does Application manager not the manage.autodesk.com say there are updates while the current version on my system isn't the latest.
And it's desktop subscription so I should get the updates.
Laurens Wijnschenk
3DTechDraw
Message 6 of 16
blair
Generally the "Manager" does, in this case when a ADSK employee posts the link/file right away before it works it's way into their automatic system. You might have your "Settings" set to check at the largest interval as well.
I'm not sure if special "Subscription" updates make it to the Manager App. I think it's just for the general SP's and Hot-Fixes.
Delta Tau Chi ΔΤΧ
Message 7 of 16
Laurens-3DTechDraw
It checks every 4 hours.
Also the SP1 is manually installed that didn't come up anywhere either.
Laurens Wijnschenk
3DTechDraw
Message 8 of 16
blair
After a conversation with one of the ADSK senior managers in a meeting at AU earlier this month, there is something else coming down the pipeline, I suspect it might be getting more of the resources. The new applet should make things easier and tie into subscription better (about all I can say due to non-disclosure contracts with ADSK).
Delta Tau Chi ΔΤΧ
Message 9 of 16
scottmoyse
Laurens,
Which version is the application manager? I've seen issues numerous times this year where it hasn't updated itself, I never know why, since it could be that the end user dismissed a prompt to update it. In any case, once updated often the product updates appear correctly. HOWEVER, I haven't seen any of the R2 or R3 updates appear for Inventor in the Application Manager. I have only managed to get those from manage.autodesk.com.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 10 of 16
Laurens-3DTechDraw
Scott,
But why don't they show in the manage.autodesk.com page?
I'll check my application manager.
Laurens Wijnschenk
3DTechDraw
Message 11 of 16
scottmoyse
Click on the product, select downloads, then search for Inventor R2, then Inventor R3. I had the same problem. They really stuffed these ones up.
Scott Moyse
Message 12 of 16
Problems here too. I downloaded R2 R3 but I can't find a way to install. latest Application manager is installed. Should be a simple click and install but not so. I assume they are not installed as I can't find any confirmation anywhere they have been. Product info shows SP1 from 10-13-15 as latest.
Message 13 of 16
SBix26
@blair: I'm using Chrome to read the forum, and all I need to do to see the embedded images is right click and select "Open image in new tab".  In this particular case, the images are at full screen resolution!
Sam B
Message 14 of 16
Laurens-3DTechDraw
Exactly this now!
Laurens Wijnschenk
3DTechDraw
Message 15 of 16
Hey Laurens,
  Had an Inventor SP1 update from 12-15 which when applied now shows all the missing updates. Go figure that one out.
Message 16 of 16
Laurens-3DTechDraw
For me it seems like installing an older version of the application manager did the trick.
Laurens Wijnschenk
3DTechDraw
