why do I get this error ?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 8
when I try to constrain this cirkel to the origin point Iget an Error?
but if I just pull  it a lillte away and do the same .. It make no error .. Why is that ... error in what i do or the program .. It is inventor 2020 i use
Replies (7)
Message 2 of 8
kacper.suchomski
Hi
The midpoint projection is missing in this sketch.
(view in My Videos)
Kacper Suchomski
Message 3 of 8
but why does it work when I move it ? I select it in the browser  both times 🙂
Message 4 of 8
kacper.suchomski
I don't know. I don't see your workflow.
Kacper Suchomski
Message 5 of 8
BDCollett
Tried in 2025 and it does the same.
Inventor seems to see a point already on the origin point location, as being the origin point itself. So, you can't constrain it to itself.
Try and constrain a point to the origin point when in the same location, it says it already exists.
Just an odd interaction, but a very easy one to work around.
Message 6 of 8
Frederick_Law
Something wrong with the background point selection.
When there is a point, it'll select that point.
When there is no point, it'll project one.
I use auto Project Origin:
Message 7 of 8
This is also active on my computer
Message 8 of 8
johnsonshiue
Hi! I can reproduce the behavior. It seems that Inventor is confused by the points, since they are on top of each other. Moving the circle aside relax the confusion.
Many thanks!
Software Test Engineer
