What does Styles Editor Save
jgunter3JNFK
jgunter3JNFK
Hi All,
New to Inventor and had a quick styles editor question.
When you click save...
Does this save / upload just the "active styles", "local styles", or "all styles" to the design data folder?
Cheers
kacper.suchomski
Hi
Before saving, changing the style settings applies only to the active document.
To be able to save styles permanently, change the project settings to read-save mode.
Kacper Suchomski
johnsonshiue
Hi!
As Kacper mentioned here, the Save command saves any local standards and styles that are different than the same named ones on the library back to the Styles Library.
Many thanks!
Software Test Engineer
jgunter3JNFK
Thank you for the response. Would it remove any styles if you delete / purge them?
Cheers
johnsonshiue
Hi! No, the Save command only save the selected styles back to the library. Purge is a different command and it only purge the styles within a document, not in the library.
Many thanks!
