Why cant I create a rib
drawings_bemcopvt
Message 1 of 20
drawings_bemcopvt
With regard to attached part file, why can't I create a rib for "Sketch3", or how do I create a rib.
Edit:
I have also attached the part which I was trying to draw. Only the rib feature is remaining.
Jatin
Replies (19)
Message 2 of 20
89198826955
there are many options here
1. make a 3D sketch
2. make a surface area
3 make the thickness
Message 3 of 20
89198826955
1 plane between two faces
2 2d sketch
3 extrusion
Message 4 of 20
89198826955
1.2d sketch
2. extrusion
3 plane by 3 points
4 split
Message 5 of 20
drawings_bemcopvt
I also thought of extrusion, but the bottom side does not blend with the slotted projection. It is straight, while the slot projection is circular. There remains a gap between rib and the bottom surface.
Message 6 of 20
89198826955
Message 7 of 20
89198826955
1.cut to the top of the ellipse
2. cut to edge
Message 8 of 20
89198826955
if necessary along the contour
3d sketch and loft
Message 9 of 20
Alexander_Chernikov
When used the loft - will not have a flat top face at the Rib.
Alternatively, you can provide a small gap (depending on the radius of the cylindrical face and the width of the rib) when you sketch the rib axis.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 10 of 20
drawings_bemcopvt
I have edited my question to include the drawing figure. You can see that it is a simple rib which ideally should be designed in inventor by using the Rib feature. Hence, I would like the respondents to suggest a solution using the "Rib" feature.
Message 11 of 20
JDMather
@drawings_bemcopvt
The figure is incorrect - hand drawn art created before the days of CAD.
The logical solutions are obvious when you attempt to 3D model (or go out to the shop floor and attempt to machine the art  version).
Back early in my career (in the last century) I was working on the shop floor as a machinist. I got a drawing like this (but starting from a casting) and at first thought I had scrapped the casting when it didn’t look like the drawing. Only after some logical thinking 🤔 did I realize that the drawing was wrong.
Message 12 of 20
drawings_bemcopvt
@JDMather ,
In that case I will close this question. I have just began to learn inventor and this figure was a part of my learning process and relatively unimportant.
Jatin.
Message 13 of 20
JDMather
@drawings_bemcopvt
Your first sketch is all wrong.
Do you want to learn how to use Inventor correctly?
Edit Sketch your Sketch1.
Click and drag various points/lines around the screen.
What do you observe?
I observe numerous missing geometry constraints (which should be automatic).
Also - I recommend that you go to Autodesk - Account
and download the Updates for your version of Inventor.
@drawings_bemcopvt
We can go step-by-step through correct modeling proceedure.
Message 14 of 20
johnsonshiue
Hi! The rib in this case cannot go for the full length. Or it will alter the circular edge at the top. The rib sketch needs to offset inward a bit.
Many thanks!
Software Test Engineer
Message 15 of 20
drawings_bemcopvt
@johnsonshiue
I made the sketch line a bit offset at both ends, still inventor won't create the rib.
Jatin.
Message 16 of 20
Alexander_Chernikov
You should pay attention to 2 options for Rib:
the position of the Rib relative to the sketch plane and the direction of creation of this Rib.
Watch attached video
PS.: Check that your coordinate planes coincide with the planes of symmetry of the part!
(view in My Videos)
Facebook | LinkedIn
Message 17 of 20
JDMather
@drawings_bemcopvt wrote:
@johnsonshiue
@drawings_bemcopvt
No new file Attached?
Do you want to learn how to do this correctly?
Message 18 of 20
89198826955
I want to learn right
step by step
learn to do better
can you help me?
e-mail for communication [email protected]
Message 19 of 20
JDMather
@89198826955
What version of Inventor are you using?
Can you Attach the *.ipt of your attempt to model the geometry?
Message 20 of 20
89198826955
inventor 2024
I created a "step by step" theme
put the assembly and drawings there
