Inventor Forum
White
11 REPLIES 11
Message 1 of 12
791 Views, 11 Replies
White
How do i make an object the Color "White"...I select White from color list but it is more Grey then White...same for Snow etc..etc..
Richard
11 REPLIES 11
Message 2 of 12
Mark.Lancaster
@Anonymous
See @mflayler response (or solution) in this posting.  Update:  Other suggestions are there as well so review them as well.
Mark Lancaster
Message 3 of 12
in reply to: Mark.Lancaster
Thanks Mark
Message 4 of 12
Ok i make the part White but it does not update that part color in the Assembly. Can this be done?
Message 5 of 12
mcgyvr
So you opened the part and then modified the color there right?
Now you need to "save" the new "White" to your style library and then "update" the styles in the assembly to pull in the new color modifications..
"save" and "update" are on the "Manage" tab in the "Styles and Standard" pane..
Message 6 of 12
in reply to: mcgyvr
I am unable to get the INV2013 .ipt style to update in the assembly. It is White as an .ipt but i cannot get the Assembly to update. I hit the update button on the "Manage" tab in the "Styles and Standard" (save greyed out - not selectable) ....It is something i presume i am not doing....what else can i check?
Message 7 of 12
SBix26
Lighting styles?
Sam B
Inventor Professional 2017 R2
Vault Basic 2017
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Message 8 of 12
mcgyvr
Is the style library set to read/write in your project file?
Message 9 of 12
in reply to: mcgyvr
I have set to Read-Write
Now the assembly has the White .ipt. This is now working fine for this assembly but when i go to place this assembly into another assembly the Styles does not show...what is the next step please
Message 10 of 12
mcgyvr
Is that a new or existing assembly you are trying to place the assembly into?
Is there a local appearance of white in that assembly?
Use the update button in style/standard pane of the manage ribbon again in that assembly..
Then you can also open your iam template and use the update button there to ensure the updates are there for new assemblies..
Message 11 of 12
in reply to: mcgyvr
Thanks. Got this to work
When i go the Studio the Style is again not showing for rendered image. Do i need to add for Studio?
Message 12 of 12
mcgyvr
No.. BUT studio is using a different lighting style which again will effect the color..
