How do i make an object the Color "White"...I select White from color list but it is more Grey then White...same for Snow etc..etc..
Richard
Richard
@Anonymous
See @mflayler response (or solution) in this posting. Update: Other suggestions are there as well so review them as well.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
Thanks Mark
Ok i make the part White but it does not update that part color in the Assembly. Can this be done?
So you opened the part and then modified the color there right?
Now you need to "save" the new "White" to your style library and then "update" the styles in the assembly to pull in the new color modifications..
"save" and "update" are on the "Manage" tab in the "Styles and Standard" pane..
I am unable to get the INV2013 .ipt style to update in the assembly. It is White as an .ipt but i cannot get the Assembly to update. I hit the update button on the "Manage" tab in the "Styles and Standard" (save greyed out - not selectable) ....It is something i presume i am not doing....what else can i check?
Lighting styles?
Sam B
Inventor Professional 2017 R2
Vault Basic 2017
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Lighting styles?
Sam B
Vault Basic 2017
Is the style library set to read/write in your project file?
I have set to Read-Write
Now the assembly has the White .ipt. This is now working fine for this assembly but when i go to place this assembly into another assembly the Styles does not show...what is the next step please
Is that a new or existing assembly you are trying to place the assembly into?
Is there a local appearance of white in that assembly?
Use the update button in style/standard pane of the manage ribbon again in that assembly..
Then you can also open your iam template and use the update button there to ensure the updates are there for new assemblies..
Thanks. Got this to work
When i go the Studio the Style is again not showing for rendered image. Do i need to add for Studio?
No.. BUT studio is using a different lighting style which again will effect the color..
