I am running Inventor 2010 Pro.
Is there a way to do a search to see what other assemblies a part is used in?
Solved by Mark.Lancaster. Go to Solution.
Use Design Assistant. See this link: http://forums.autodesk.com/t5/inventor-general-discussion/is-it-possible-find-where-ipt-s-are-used/m...
Mark Lancaster
& Autodesk Services MarketPlace Provider
Depending on which suite package you have, Vault Basic might be included. The once your assembly is in the Vault, you can see the where used of the parts/assemblies.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
