Help, ribbon sort of disapeared.
Using Inventor 2016.
Suddenly the ribbon interface changed, and only showing a few Icons, one for each main group.
I want i back as it was before, where everything was diplayed.
Now I have for example one tab with assemble, in that tab there are a number of Icons, I.e Components.
Previously each of these icons where expanded so everyting was displayed, now I have to select the Icon , to get the tools I need.
Twice the job.
I cannot find any way to reset/change it back.
Curtis_Waguespack
Hi ENRAD,
Without a screen shot, Ii'm sort of guessing, but I think what you want to do is click the little white/gray arrow button at the far right of the menu bar, next to the Autodesk 360 menu header.
https://forums.autodesk.com/t5/inventor-general-discussion/inventor-ribbon-is-missing/m-p/4768311#M4...
I hope this helps.
Curtis
admaiora
It's a trap!
https://forums.autodesk.com/t5/inventor-ideastation/it-s-a-trap-minimize-to-panel-button/idi-p/51391...
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Wow, what a funktion, obviously created to destroy our brains.
I tried it, however I selected the dthree different selections manually, the correct one is obviously not there.
But cycling through it fixed it.
