Evoluent Vertical Mouse with Inventor
Message 1 of 13
Hi, as anyone been using the Evoluent Vertical Mouse with Inventor? I need to find an Ergonomic mouse, the regular mouse is creating major pain in my wrist.
Marty
Replies (12)
Message 2 of 13
I have not seen anyone here that uses it, or at the very least, have said they used it.  The reviews seem to be positive about it though.
A lot of people give them flak, but I use a trackball.  I use THIS ONE in particular and love it. It does take some time to get use to, but I won't go back to the normal mouse, I like this too much.  I've also converted a few where I work to do the same. They all had wrist pain before.
I also use a SpaceMouse in the left hand for pan/orbit/zoom functions.  Love that as well.
Message 3 of 13
blair
"Standard" mouse leaves much to the imagination. I use the CadMouse from 3dConnexion along with there SpacePilot Pro. This mouse finally replaced my old Logitech MX Revolution mouse.
www.3dconnexion.com
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 13
Curtis_Waguespack
@blair, Are you saying I need to upgrade?
@Anonymous if you don't get any direct feedback, have a look at this link for some mentions of the mouse you're asking about in other Autodesk product forums:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=Evoluent+Vertical+Mouse+
I hope this helps.
Curtis
Message 5 of 13
blair
If your cell phone is a Motorola Brick, then no!
Delta Tau Chi ΔΤΧ
Message 6 of 13
SBix26
My next-cubicle neighbor uses one, and it works well for him, dealing with serious RSI (repetitive stress injury).
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 7 of 13
salariua
I have tried the evoluent mouse and found it harder to work with. It was hard to get a firm grip (kind of slip out of hand) and the fact that you hold the mouse high above the table it decreased my precision to move it around. Bear in mind that I have ALL my mouses (mices) set to maximum speed so I can be on both screens fast with as little movement as possible.
I do have a trackball similar to yours Aaron but it's the Logitech M570. It's faster for work in general except for AutoCAD.
Nothing beats the regular mouse for AutoCAD from a speed point of view, especially with the 2 thumb buttons set to Enter and Escape. I have always used 3 fingers on the mouse: Index finger on click, middle on wheel, ring finger on right click ...etc. For AutoCAD stuff I still use the Roccat Kone XTD, just for speed (I do a lot of P&ID's)
I have a palm type of grip and so I love a large mouse but the down size of the M570 trackball (any trackball for that matter) is that they need cleaning up ALL THE TIME. Smallest dust particle makes the pointer jump and hard to work with. I have been searching everywhere and can't find a trackball with pad instead of ball (trackpad?, touchball? padball? 🙂 ), that way I don't need to clean it all the time. I was hopping that the tactile pad (tactile ball) would solve the problem.
The CAD Mouse from 3dConnexion didn't inspire me but that's just me (read my comments here on design and motion).
Home I use a Logitech G602 mouse but there are some good clones on Amazon now, a lot cheaper too (wish I knew that earlier).
Here are my stats on mouse usage: In about 5 hours of design time, I can squeeze out of a normal day, I get around ~5000 clicks and ~3500 scrolls.
@Anonymous: where about are you located? maybe I can get one of my colleagues to send you a second hand one for review. I bet there's one that they don't use sitting around here somewhere.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 8 of 13
swalton
I've used the same unit for 7-8 years.  I like it.  Plan to spend some time adjusting your mouse habits to the different layout.
I also use a SpacePilot with lots of programmable buttons.
Added Bonus: No one else likes run my computer. Smiley Wink
Steve Walton
Inventor 2025
Vault Professional 2025
Message 9 of 13
mcgyvr
Marty
have you tried something simple first like a wrist pad specifically for use with a mouse?
It elevates the wrist slightly to put it back into natural alignment.. (works great for me.. and its a nice "stress ball" too)
I run one like this..
http://www.staples.com/IMAK-Mouse-Wrist-Cushion-with-ergoBeads/product_570953?cid=PS:GooglePLAs:570953&ci_src=17588969&ci_sku=570953&KPID=570953&lsft=cid:PS-_-GooglePLAs-_-570953,kpid:570953&gclid=CM2JzNTwocoCFcETHwod8u8DZg
and love my level 10M gaming mouse..(its got friggin BMW suspension/adjustable angles,etc...)
http://www.ttesports.com/productPage.aspx?p=39&g=ftr#.VpOwhfkrKHs
Message 10 of 13
salariua
The one thing I can't adjust on all my devices is the position of the wheel. I have a rather long fingers and panning and clicking with the wheel it's really painfull.
Can you adjust the position of the wheel on the 10M?
Adrian S.
blog.ads-sol.com
Message 11 of 13
mcgyvr
No but the left/right buttons are almost 2" long and the wheel is centered on that so there is plenty of "range" there..
Message 12 of 13
swalton
A mouse with a dedicated middle button (not using the mouse wheel) might be a help.  That would eliminate clicking on the wheel, you would only need to zoom with it.  Training yourself to use a different finger on the wheel might help too.  I can reach the mouse wheel with either my 1st or 2nd finger on my VM2.  My 2nd finger stays on the middle button.
Add a 3d controller for zoom/pan, and you don't need to touch the wheel at all.
Steve Walton
Inventor 2025
Message 13 of 13
I use an Evoluent vertical mouse.  I love it.  I've been using it for 6 years or so.  The angle of your wrist helps with carpel.  Also, I dedicate the middle button to middle click, right button (ring finger) to right click.  This helps a lot.  Middle clicking on the wheel gets old and on many mice, it take more force.
