Where is the Harness & Cable (Panel) in Inventor Professional 2021
thomas.loveMETNY
thomas.loveMETNY
Where is the Harness & Cable (Panel) in Inventor Professional 2021?
I searched show panels and it is not there.
mcgyvr
I'm not sure which one you are referring to but in the part environment you can access the "Harness" panel by being on the "3d Model" tab and accessing "show panels" and selecting "Harness".. That will give you the "Pin, pin group and properties" buttons..
If you are in an assembly and want to create a new harness you can either right click and select "Create Harness" from that menu or switch to the "Environments" tab and press the "Cable and Harness" buttons..
Gabriel_Watson
Check if your module is loaded in Inventor (start or open an assembly and see if Loaded/Unloaded is check marked ON):
thomas.loveMETNY
That is the issue.. I have the Harness and Cable option under 'Environments' in the assembly, but no Harness option in the part menu panel (Show Panels) 3d Model" tab.  And yes, I realize the attachment(Pic) is from Inventor 2017Missing this PanelMissing this Panel
Gabriel_Watson
Open/activate a part (IPT) and checkmark the following (inside the 3D model tab):
r.hemelop
the ribbon is there but not active
johnsonshiue
Hi! Did you check if the Routed System: Cable & Harness Add-In is loaded (Tools -> Add-Ins)?
Many thanks!
Software Test Engineer
