Inventor Forum
whats going on here
4 REPLIES 4
egghead
148 Views, 4 Replies
whats going on here
can someone tell me what is going on with this part. if you pattern the holes around, it created the funny face within the sphere, pattern of 7 is fine, pattern of 9 is ok but it wont let me do 8 and i need 8.
4 REPLIES 4
in reply to: egghead
It's not, as it should be, I think.
I was able to work around it, by doing a pattern of 4, and then mirroring
it.
Greetings
Waltrer
schrieb im Newsbeitrag news:5005346@discussion.autodesk.com...
Seems like a peculiar graphics problem. If I zoom in the problem goes away, and if I make an idw the problem is not there.
I confirmed it is a display issue. The underlying part geometry is healthy.
Chun Du
Autodesk Inventor QA
wrote in message news:5005346@discussion.autodesk.com...
Hmm. I was able to delete the faulty face, and the volume turned into a
surface.
Walter
"Chun Du (Autodesk)" schrieb im Newsbeitrag
news:5005699@discussion.autodesk.com...
Chun Du
