when I import STEP models (probably others as well but I don't do that often), the resultings parts or assemblies don't seem to be created our templates, but rather, something else, and I don't know WHY? And what template files used exacty, because I coudln't find one that matches the results.
I also tried naming out template files differently, but that didn't help.
Could anyone please explain what is used here? And how to make Inventor use the ones that we have configured? Thanks!
Hi!
These processes use a "system template", not a template you have in the regular template's folder.
A similar situation happens when you convert a solid part into sheet metal, it uses the "sheet metal system template".
I wonder if it's now possible to change/edit those system templates, i think this was not possible in the previous versions.
If you keep a "Standard.ipt" template for parts under your Templates root folder, then Inventor should be using that as the default. Same for IAM/assemblies and a Standard.iam.
You could change those Standard files to a different folder than the rest of your templates if you wish, under Tools tab > App. Options > File > Default Templates path.
Similar thread:
https://forums.autodesk.com/t5/inventor-forum/step-file-import-template/td-p/7624948
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
