Every disc cam generated by Design Accelerator in Inventor has the center axis added. Using that axis, make a sketch on the face of the cam, project the axis and use it as a circle center. You will easily see the eccentricity. See attached screencast.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
