What is the difference between Autodesk® Inventor® and Autodesk® Inventor™.
Message 1 of 20
I tried downloading the latest updates from the Autodesk site
But I have found out two different variants of Inventor
can someone tell me what is the exact difference
when an update is available as Inventor 2016 SP2
Can it be installed to either of the variants
Replies (19)
Message 2 of 20
Mark.Lancaster
@Anonymous
Can you show what you're seeing..  You subject line says the same thing..   Inventor is Inventor..  Smiley Wink
Are you talking about Inventor LT, Inventor and Inventor Pro?
Are you talking about the 2016 version
Mark Lancaster
Message 3 of 20
mcgyvr
https://www.autodesk.com/compare/inventor-vs-inventor-lt
Message 4 of 20
JDMather
https://knowledge.autodesk.com/support/inventor-products/downloads?release=2016
Message 5 of 20
Ray_Feiler
Trick question maybe?
First version both Autodesk and Inventor are registered (R)
Second version Autodesk is registered (R) and Inventor is trade marked (TM)
You can send my cash prize to your favorite charity.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 6 of 20
Yes, I am talking about Inventor 2016
Below is the snapshot of available downloads for Inventor 2016
My question is that I  am using Autodesk® Inventor® 2016. So which Service pack should I download?
Message 7 of 20
Thanks for the reply
But I am not asking about the difference between Inventor and Inventor LT
Message 8 of 20
JDMather
Do you have Inventor or do you really have Inventor Professional?
I think the Service Pack is the same for both, but the reason you see it listed twice is that you have both standard Inventor and Inventor Professional.
Bottom line - I would download the one for the version of Inventor that you are going to apply - standard or Professional.
Message 9 of 20
Mark.Lancaster
@Anonymous
One is for Inventor Pro
One is for Inventor (standard).
Which version of Inventor do you have?  Can you do FEA, Cable & Harness, Tube & Pipe, Dynamic Sim?  If you can than you have the Inventor Pro version.
Mark Lancaster
Message 10 of 20
Thank you @JDMather,
I have been using the same link to watch out for the latest updates
But I am facing issue
when downloading the products under  (for Customers with Subscription) section
I am being redirected to another page (https://manage.autodesk.com/cep/#products-services/updates)
In which I couldn't find the version of inventor that I am using
So in process of knowing what is the big difference between Autodesk® Inventor® and Autodesk® Inventor™.
Can the same updates be applied to either of the products
Message 11 of 20
@Ray_Feiler: Can you please be elaborate
Thanks in advance
Message 12 of 20
JDMather
Can you answer this question?
Do you have Inventor or do you have Inventor Professional?
Message 13 of 20
Hi @JDMather
I am using Autodesk® Inventor® Professional 2016Invy 2016 Details.jpgInvy 2016 Details.jpg
Can you let me help in downloading the corresponding updates
Message 14 of 20
JDMather
Your latest image indicates that you have Update 2 for Service Pack 0 (Service Pack 1 not installed).
So, simply follow the instructions here
working your way up the list to Update 1 for Service Pack 2.
You would get an error if you attempted to install incorrect Update or Service Pack - so you can't do anything wrong.
Post back with any error messages that you get during the process.
Message 15 of 20
Hi @Mark.Lancaster
So can you confirm to download and install the Autodesk® Inventor™ Professional 2016 64-Bit Service Pack 2 for the one which I am using now?
Message 16 of 20
@JDMather
Roger that.
I have already started downloading
Will post an update here if found any issue while updating
Many Thanks
Message 17 of 20
S_May
@Anonymous
The R in the circle stands for "Registered"
The TM stands for "Trademark"
>>>>wordpress.com<<<<
Smiley Happy
Message 18 of 20
Hi @S_May
Thanks for the info
What exactly does it mean
Can you please explain further on how it affects the application & usage
Message 19 of 20
S_May
@Anonymous
It has no effect on the product, it is a legal thing of the products, TM is also available in the principle only in the USA
trademark-symbol-tm-vs-r
Message 20 of 20
@JDMather
I have installed all the updates as mentioned
Can you confirm is this the latest version of 2016 or still any updates are pending to installed
