Hi.
How can I change a bolt size that is in content center, using iAssembly table?
Thanks!
Hi.
Thanks!
Hן
You can't change the size of the default content center
you can copy it to your read/write library and change if from there
or after place one content center bolt as custom change the size and with ipart add more member of that bolt with different size
regards
You can't out of the box.
What you can however, is to export the family table to excel and then use it on a generated member to convert it to iPart which allows changing members.
Thank you both for the reply. Thats what I thought.
Is there a way to do it using iLogic or VBA?
Thanks!
I've seen it done before but I don't have the code for it.
link2 (this one was reported to work)
