Custom Content Center Errors in 2017
amarcoc
amarcoc
Hi.
How can I change a bolt size that is in content center, using iAssembly table?
Thanks!
eladm
You can't change the size of the default content center
you can copy it to your read/write library and change if from there
or after place one content center bolt as custom change the size and with ipart add more member of that bolt with different size
regards
salariua
You can't out of the box.
What you can however, is to export the family table to excel and then use it on a generated member to convert it to iPart which allows changing members.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
amarcoc
Thank you both for the reply. Thats what I thought.
Is there a way to do it using iLogic or VBA?
Thanks!
salariua
I've seen it done before but I don't have the code for it.
link1
link2 (this one was reported to work)
Adrian S.
blog.ads-sol.com
