What does Use Style Library = read/write actually mean?
oransen
oransen
I've looked at posts and the help files but I still do not know what "Use Style Library = read/write" actually means
To be honest the handling of styles in inventor seems infinitely more complex than it needs to be....  😞
Accepted solutions (3)
Lewis.Young
When the style library is set to read-only you can only use the styles and not edit them. If set to read-write, you can both use the styles and modify them/create new ones.
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Mark.Lancaster
@oransen
It is a basically a toggle for this button (for styles)
When the project file is set to read/write the save button is enable and thus allows you to save your styles back to the global styles or the styles that are in XML form in your designated design data folder.   Have this enable allows any user having this option to do this..  In my opinion its a bad thing because at some point it will lead to a styles conflict.
Update:  @Lewis.Young This statement ":When the style library is set to read-only you can only use the styles and not edit them" is not really 100% true..  Smiley LOL   There's local and global styles.   Local styles can be modified even when the the styles library option in the project file is set to read-only.   If its read-only the user is not permitted the save option and thus they are unable to save back to the global styles.
Mark Lancaster
Mark.Lancaster
@oransen
Not sure if this will help or not but here's an Autodesk University Class (that @cbenner and I did) handout about managing your styles.
Mark Lancaster
oransen
@Mark.Lancasterthanks for the PDF, it has edged me further along to a solution of another problem I had.
But the expletives deleted as I try to understand the yogic contortions of styles.....!
