Making .ipt from .dwg file
Message 1 of 8
I want to create an .ipt file from .dwg file.
This is what I've done so far
1. Create a new part
2. Create a 2D sketch
3. Insert .dwg file using Sketch >> insert
And then followed this solved post
but It's not working for me
Would be great if someone could make me a screencast or something
Replies (7)
Message 2 of 8
IgorMir
I would suggest - create a sketch in Inventor and extrude it afterwards.
Cheers,
Igor.
Web: www.meqc.com.au
Message 3 of 8
Lewis.Young
See the screencast attached for how to do this 🙂
Lewis Young
Windows 7 x64 - 32GB Ram
Intel Xeon E5-1620 v2 @ 3.70GHz
nVidia Quadro M2000 - 4GB
Inventor Professional 2017.3
Vault Basic 2017
3ds Max 2018
Message 4 of 8
Lewis.Young
Hmm it didn't seem to attach... https://autode.sk/2OCuE0m
Message 5 of 8
Mark.Lancaster
@Anonymous
Not sure what Inventor version you're using but here's another workflow you could use to take 2D to 3D..
https://synergiscadblog.com/2015/06/16/turning-2d-flat-geometry-into-3d-2/
Mark Lancaster
Message 6 of 8
TheCADWhisperer
First thing I recommend is cleaning up the AutoCAD dwg BEFORE importing into Inventor.
There is some rubbish geometry well away from the Origin and the Target geometry.
The target geometry should be moved to the Origin.
The Target (and Rubbish) is so far from the Origin that it appears as mere dots in this screen capture.
Also, you did not state what version of Inventor you are using.
Message 7 of 8
TheCADWhisperer
The units for the geometry in AutoCAD is set to Inches.
When I measure the geometry - I suspect that the intended units should be mm.
The AutoCAD operator could benefit from training in AutoCAD.
Message 8 of 8
TheCADWhisperer
The AutoCAD geometry is of very poor workmanship with several locations where lines are not trimmed to tangent arcs.
I would not trust the source.
