True, but there is a good chance that it might meet the needs of someone who
needs this functionality today. There may be issues with this in his
company's workflows/standards, but most can be mitigated. For example, the
assembly could be given a phantom BOM structure so the SM part would be the
only item that appears in any BOM. The idea is that this weldment assembly
only has a single component instance, the SM box.
....thinkin' outside the SM box
Neil
"Dennis Jeffrey" wrote in message
news:5534104@discussion.autodesk.com...
Aha! but he wanted to do it in part, not assy mode... 🙂
Dennis Jeffrey, AICE, MICE
260-312-6188
Instructor/Author/Sr. App Engr.
Inventor 11 Professional SP2
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
"Neil Munro" wrote in message
news:5534120@discussion.autodesk.com...
Yes, with some non-standard workflow. (IV11 for sure, don't have IV10 to
check if it works there also)
1. Create the SM part.
2. Place the part in a new Weldment assembly.
3. Use groove welds to close the gaps (see attached image)
Neil
wrote in message news:5533988@discussion.autodesk.com...
Is it possible to create weld beads on parts and not just in assemblies?
Example: A sheet metal box which needs welded edges so there are no leaks.
