Our company specifies multiple weld procedures in the weld tail notes. Problem is that inventor doesn't seem to have an option to make the tail size fixed. As we add more lines on the note, the tail size increase which makes it look weird. Just imagine this all over the drawing when we show multiple welds in one drawing. Has anybody found a workaround for this?
Have you tried going to the style editor and seeing if there is any option to reduce the size of the weld note?
Does your note need to occupy 7 lines of text or can you knock it down to 2 or so?
Granted the tail will still grow in size accordingly, but at least it won't be so large.
Jim O'Flaherty
