I have looked through the forum, and this doesn't seem possible, but I want to make sure I'm not missing something. I want to display visible edges of referenced parts as phantom and the hidden lines as hidden. Currently if select "Edges As Part" in the Display Style dropdown box (in the Model tab of the Drawing View dialog box), the visible edges of referenced parts show as continuous and the hidden lines show as hidden. But if I select "Edges As Reference", all the lines show as phantom, even the hidden lines.
Solved by theo.bot. Go to Solution.
By default the answer is no you can't set this in the object defaults. But if you really need these objects shown in a different layer, then you can do it manually. By playing with layer visibility state and cross selection you can quickly assign the geometry to a new layer.
Edit: I added a small sample video.
