Visual indicator, in assembly browser, showing part is completely constrained?
Borsht
Message 1 of 9
Borsht
Is there any setting available where, when I am in an assembly, the browser would show which parts/subassemblies are completely constrained?  Right now in order to find out, I am going to the assembly viewport, selecting the part, and moving the mouse to see if the Ø symbol comes up. If it does I know the part is fully constrained.  If it doesnt, or moves, then I know I need to add constraints to fix it.
Inventor 2017
Replies (8)
Message 2 of 9
Curtis_Waguespack
Hi @Borsht
Give the Degrees Of Freedom tool a try:
http://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-3BCBF614-CF92-4980-A965-80AEAFEF768E
I hope this helps.
Curtis
Message 3 of 9
Borsht
I appreciate that, but was hoping for a more permanent indicator, like a + or - showing up as a default in the browser tree, next to the file name.  The DOF symbols just get messy in the assembly viewport.
Inventor 2017
Message 4 of 9
Mark.Lancaster
@Borsht
You can use this tool https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6524519755338237990&appLang=en&os=Win64 and its free.
As long as you are using Inventor 2018, 2019, or 2020.
Mark Lancaster
Message 5 of 9
Borsht
That would work, but unfortunatly I'm on 2017.
Inventor 2017
Message 6 of 9
Mark.Lancaster
What do you mean...
Its working for me in 2017..  😀
But I'm not here to promote modifying someone else program to get it to work in 2017.  Exit Inventor and download and install it.
Before launching Inventor 2017 again, go to this location C:\ProgramData\Autodesk\ApplicationPlugins\Hjälte ShowFullyConstraint.bundle\Contents and using notepad, open Hjalte.ShowFullyConstraint.addin and change the 21 that's there to 20.
Save the file and launch Inventor 2017, do you get a message that the add-in is blocked?   Oh by the way don't tell anybody that I told you about this...  😎
Update:  Any one that comes across what I have stated here...   It should be done at your own risk, I'm not promoting this workaround or held libel for showing this work-around and most likely you'll not get any support fromt the vendor of this add-on if you select to modify it for unsupported versions.
Mark Lancaster
Message 7 of 9
Curtis_Waguespack
@Mark.Lancaster wrote:
.....  Oh by the way don't tell anybody that I told you about this...  😎
We know you outsource your add-in hacking work to this guy 😉
Message 8 of 9
johnsonshiue
Hi! On top of what Mark and Curtis already mentioned, this is one of the workflows we are working to improve. Please feel free to sign up Inventor Beta (https://bit.ly/InventorBeta) and you can try out the latest in-development build in a browser. You can give feedback to the project team.
Many thanks!
Software Test Engineer
Message 9 of 9
lena.talkhina
Hello @Borsht  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
