Visibility Not Working for Solid Bodies in *.IPT file
nico.villarica2U5YQ
Message 1 of 10
nico.villarica2U5YQ
I've recently encountered a problem wherein visibility does not work properly in my ipt file. Whenever I toggle/untoggle visibility for any solid body nothing seems to happen, the solid stays visible regardless. So far this has happened to only one file. I've never encountered this before, and I'm hoping that this is a simple matter of having overlooked something simple.
Any help would be appreciated.
Als, I'm using Inventor Professional 2017
Replies (9)
Message 2 of 10
WHolzwarth
Hard to say without having access to the file.
I suspect, because it looks like being in sheet metal environment.
Walter Holzwarth
Message 3 of 10
nico.villarica2U5YQ
Apologies, I forgot to attach the file. Attached the files in this message.
Also, I tend to use Sheet Metal Environment all the time and this has never happened before.
Thanks.
Message 4 of 10
M_Mertens_Intec
Hey, 🙂
i just checked your file. I am thinking that is what you are looking for. Right??
I saved the file and ad it. Can you check, how it opens in your Inventor??
Marcus Mertens
Anlagenplanung and Design
INTEC Engineering GmbH
76646 Bruchsal
Message 5 of 10
nico.villarica2U5YQ
Hey, thanks for taking the time.
Yes, that's exactly what I need to happen.
Unfortunately I can't open your file, error message "Error reading in RSe stream". Must be a version compatibility issue with Inventor.
Message 6 of 10
M_Mertens_Intec
Yes it seems so. I use 2022. You have an older Version??
Marcus Mertens
76646 Bruchsal
Message 7 of 10
WHolzwarth
Perhaps an update will do. I could switch invisible with 2017.4.12 (Build 256)
Walter Holzwarth
Message 8 of 10
BDCollett
Try creating a new view rep as a test. Otherwise, I would assume the model is bugged. It works fine when I open it in 2023 as well.
Message 9 of 10
johnsonshiue
Hi! I don't have 2017 to verify the behavior. It could be a corrupted design view as Walter mentioned. Or corrupted scene graph. Go to Manage -> Rebuild All or move EOP to the top and then back to the bottom. Does it help?
Many thanks!
Software Test Engineer
Message 10 of 10
nico.villarica2U5YQ
I tried this and it worked! The views do seem to be bugged somehow. Perhaps an update to a later version would be the best solution. But for now I at least have a workaround.
Thanks!
