virtual parts in an assembly
johan.degreef
Advisor Advisor
johan.degreef
My main assembly is finished. now i need to to add 50-60 lines in the partlist, like paint, welding material etc. What would be the best workflow?
Make a seperate subassembly with virtual parts in it, that I place as a whole in my main assembly? or...?
It seems when I create a virtual part with my normal ipt template selected, the custom iproperties does not come through. Is there a seperate template that should be used when working with virtual parts?
Thx, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
bradeneuropeArthur
  • Add virtual parts indeed
  • add them as custom to the partslist
  • use vault items to achieve this
  • what do you mean with that (Normal Ipt) there is no template for virtual parts, is it?
Thx, Johan
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
johan.degreef
It seems not, so I cannot predefine custom iproperties then?
bradeneuropeArthur
Is far as I know not, indeed.
You could create a rule or add in for it to create VP with properties defined.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
