I created an offset surface, and would like to view this surface when I'm in the from view. See attached Screencast.
Any help would be appreciated.
thanks in advance
4adfdd83-2349-495a-9fb2-ad2305787d4d,640,620
Can you just paste a link to the screencast instead of attaching it into the message?
Andrew In’t Veld
Designer
Andrewiv,
If you create a flat surface, then try to view the surface from the side it should show up as a line. I understand that a surface has no thickness, but why would I ever what to NOT see it?
Works fine here, there must be something else going on?
OK, that helps thanks!
Yeah, that would be great if I could see what your seeing. I did another test, and when I create a surface, then try to look at it's edge....nothing!!! If I hover the mouse of it, it shows up.
Attach file here that exhibits this behavior.
Looks like toggling between "shaded with edges", "wireframe" then back to "shaded with edges" is a good work around, thanks.
I don't see an option for searching for the URL to paste?
If you go and look at your screencast under your profile, you should be able to just copy/paste the address.
I did just look at your screencasts and I don't see one that refers to this problem. Could you try another one?
Andrew In’t Veld
Designer
Hi Todd,
Another option might be turning off Translucent option (right-click on the Offset surface -> uncheck Translucent). If you like it, you can go to Tools -> App Options -> Part -> check "Opaque surfaces."
Many thanks!
