View a surface from it's edge
ToddPig
ToddPig
I created an offset surface, and would like to view this surface when I'm in the from view.  See attached Screencast.
Any help would be appreciated.
thanks in advance
4adfdd83-2349-495a-9fb2-ad2305787d4d,640,620
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
Replies (14)
andrewiv
There is no screencast so it's a little hard to figure out what you're looking for.
Andrew In’t Veld
Designer / CAD Administrator
ToddPig
I'm not able to add my Screen Cast!!
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied
Inventor 2018
iParts = iHeadache
andrewiv
Can you just paste a link to the screencast instead of attaching it into the message?
Andrew In’t Veld
ToddPig
Andrewiv,
If you create a flat surface, then try to view the surface from the side it should show up as a line.  I understand that a surface has no thickness, but why would I ever what to NOT see it?
Inventor 2018
iParts = iHeadache
JDMather
Works fine here, there must be something else going on?
andrewiv
Is this what you're talking about?
Andrew In’t Veld
SBix26
If you change visual style to Shaded with Edges (or any other visual style that shows edges/wires), flat surfaces are visible when viewing from their edge.  Shaded or Realistic styles, no.
Sam B
Inventor Pro 2021.1 | Windows 10 Home 2004
LinkedIn
ToddPig
OK, that helps thanks!
Inventor 2018
iParts = iHeadache
ToddPig
Yeah, that would be great if I could see what your seeing.  I did another test, and when I create a surface, then try to look at it's edge....nothing!!!  If I hover the mouse of it, it shows up.
Inventor 2018
iParts = iHeadache
JDMather
Attach file here that exhibits this behavior.
ToddPig
Looks like toggling between  "shaded with edges", "wireframe" then back to "shaded with edges" is a good work around, thanks.
Inventor 2018
iParts = iHeadache
ToddPig
I don't see an option for searching for the URL to paste?
Inventor 2018
iParts = iHeadache
andrewiv
If you go and look at your screencast under your profile, you should be able to just copy/paste the address.
I did just look at your screencasts and I don't see one that refers to this problem.  Could you try another one?
Andrew In’t Veld
johnsonshiue
Hi Todd,
Another option might be turning off Translucent option (right-click on the Offset surface -> uncheck Translucent). If you like it, you can go to Tools -> App Options -> Part -> check "Opaque surfaces."
Many thanks!
Software Test Engineer
