Inventor Forum
Vertical Dimension
40 REPLIES 40
Message 1 of 41
2822 Views, 40 Replies
Vertical Dimension
To begin this sketch I need Vertical Dimension between two parallel lines (indicated in the diagram). Only Horizontal Dimension is given. Is there any other way to find out Vertical Dimension between two parallel lines?
I found by using coordinate geometry.
d = .75cos30
40 REPLIES 40
Message 2 of 41
mdavis22569
are you looking to do this?
Mike Davis
Message 3 of 41
in reply to: mdavis22569
Yes I am looking that dimension. But this  dimension is not given only through the calculation you can get. I wish to know is there any way in Inventor to know this dimension.
Message 4 of 41
JDMather
All of the needed dimensions are given.
You should (almost) never need trigonometry in Inventor - use geometry (which solves the trig).
Use geometry constraints, use geometry constraints, use geometry constraints.
Did I mention, use geometry constraints?
You are missing Parallel and Perpendicular constraints.
You should never ever use Fixed constraint.
Keep in mind that that drawing is ancient - long before there was CAD.
(I did it back in the last century on the drawing board when I was in school.
The dimension arrows are not exactly correct (should be perpendicular to the parallel faces).
Actually, that looks like a rip-off of the original art.  The dimension isn't drawn correctly.
Message 5 of 41
mdavis22569
They gave you the .75 dimension, so you can model it to that thickness.
Continue modeling it to the provided dim's and you should get everything you need to make it to what they are showing.
The way you questioned it ...you made it seem like yo uwere asking to to get that type of a dim...
and you programmed in the .65 yourself manually ...
Mike Davis
Message 6 of 41
in reply to: JDMather
How get needed dimension "d" to draw the sketch.
Message 7 of 41
mcgyvr
You don't need that dimension as already stated.. (he is asking about the red line not the .75 dimension thats already there)
But even looking at the drawing the dimension is .750-.125=.625
But again you don't need it..
You model the part complete WITHOUT THE FILLETS first.
So use the .750 dimension thats already given..
Then when done with that go back and add all the .125R fillets/rounds.
Message 8 of 41
mdavis22569
edited to add screen cast ..
change the .65 to .75, add the .125 r fillet and you'll get the dim's you're looking for.
Mike Davis
Message 9 of 41
Book suggest me to use Fixed constraint. That is why I used it.
Message 10 of 41
mdavis22569
ok ...but that has nothing to do with the thickness.. just keeps it located at that point with the origin.
Mike Davis
Message 11 of 41
JDMather
No, it does not say use Fixed Constraint.  It says to fix your corner to 0,0,0.  That means add a Coincident constraint between that point and the projected origin (which Inventor will do for you automagically if you are sketching correctly).
Message 12 of 41
What does it mean?
Message 13 of 41
mdavis22569
just like it says
Fix Corner at 0,0,0 ....  you could constraint that corner to the origin point
you have of the values because of the plane .. so you need a horizonal and vertical to the origin.
Mike Davis
Message 14 of 41
mcgyvr
What does it mean?
It means do not use fixed constraint.. Use coincident instead..
Using coincident will allow the point to move in relation to the point it was constrained to if you make changes to the sketch.
If you use a fixed constraint then that point will NOT move properly..
Message 15 of 41
JDMather
You could, of course, use a Fixed Constraint - but I recommend that you forget that constraint even exists.
I have seen too many beginners use it improperly and then it is impossible to break their bad modeling habits.
The only time I use fixed constraint is to test Sketch Blocks or Punch Sketches - and then I delete it once my test is over.
These two topics are way beyond what you are ready for at this time.
If you think you need a fixed constraint - ask questions.  You now know that it is almost certainly incorrect constraint to use.
Message 16 of 41
I know Coincident Constraint. I know Fix point. No idea about Fixed Constraint.
Message 17 of 41
mcgyvr
fix is the same as fixed..
JD is saying don't use "fix" just use "coincident" to constrain that corner point to your origin center point
Message 18 of 41
JDMather
Serenity now JD, serenity now.
OK, back to work.
These are ALL geometry constraints.
Left to right, top to bottom
Coincident, Colinear, Concentric, Fixed
Parallel, Perpendicular, Horizontal, Vertical
Tangent, Smooth (forget about this one too, at least for then next couple of years), Symmetry (mirror), Equal
They constrain (remove Degrees of Freedom (DoF) from your geometry in logical ways so that your geometry behaves in a logical manner when edited.
Message 19 of 41
I use all geometry constraints frequently. But I have no idea about Fixed Constraint.
In the above blur tools are the Fixed Constraint?
Message 20 of 41
I tried to redraw the model. How to make it fully constraint without using trigonometry.
