Your question is sort of ambiguous, which direction, or axis, do you consider vertical? You can use assembly constraints to position a part in any orientation you desire. Take a look at the screencast. If you would define your question a little more, maybe the members of the forum will be able to assist you further.
John Hackney, Retired
