- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Control point, equation, and intersection curve creation. API Sample
i am getting Error
while using the sample API code
Public Sub SketchCurves()
' Create a new part.
Dim partDoc As PartDocument
Set partDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
Dim partDef As PartComponentDefinition
Set partDef = partDoc.ComponentDefinition
' Create a 2D sketch on the X-Y plane.
Dim sketch1 As PlanarSketch
Set sketch1 = partDef.Sketches.Add(partDef.WorkPlanes.Item(3))
Dim tg As TransientGeometry
Set tg = ThisApplication.TransientGeometry
' Create a spline based on control points.
Dim pnts As ObjectCollection
Set pnts = ThisApplication.TransientObjects.CreateObjectCollection
Call pnts.Add(tg.CreatePoint2d(2, 0))
Call pnts.Add(tg.CreatePoint2d(4, 1))
Call pnts.Add(tg.CreatePoint2d(4, 2))
Call pnts.Add(tg.CreatePoint2d(6, 3))
Call pnts.Add(tg.CreatePoint2d(8, 1))
Dim controlPointSpline As SketchControlPointSpline
Set controlPointSpline = sketch1.SketchControlPointSplines.Add(pnts)
' Create a 2D sketch on the Y-Z plane.
Dim sketch2 As PlanarSketch
Set sketch2 = partDef.Sketches.Add(partDef.WorkPlanes.Item(1))
' Create a spline based on an equation.
Dim equationCurve As SketchEquationCurve
Set equationCurve = sketch2.SketchEquationCurves.Add(kParametric, kCartesian, _
".001*t * cos(t)", ".001*t * sin(t)", 0, 360 * 3)
' Create a 3D sketch.
Dim sketch3 As sketch3D
Set sketch3 = partDef.Sketches3D.Add
' Create a 3D spline based on control points.
Call pnts.Add(tg.CreatePoint(10, 0, 0))
Call pnts.Add(tg.CreatePoint(12, 1, 3))
Call pnts.Add(tg.CreatePoint(12, 2, -5))
Call pnts.Add(tg.CreatePoint(14, 3, 2))
Call pnts.Add(tg.CreatePoint(16, 1, -3))
Dim controlPointSpline2 As SketchControlPointSpline3D
Set controlPointSpline2 = sketch3.SketchControlPointSplines3D.Add(pnts)
' Create a 3D spline based on an equation.
Dim equationCurve2 As SketchEquationCurve3D
Set equationCurve2 = sketch3.SketchEquationCurves3D.Add(kCartesian, _
".001*t * cos(t) + 8", ".001*t * sin(t)", "0.002*t", 0, 360 * 3)
ThisApplication.ActiveView.Fit
' Extrude the 2d curves.
Dim prof As Profile
Set prof = sketch1.Profiles.AddForSurface(controlPointSpline)
Dim extrudeDef As ExtrudeDefinition
Set extrudeDef = partDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(prof, kSurfaceOperation)
Call extrudeDef.SetDistanceExtent(6, kSymmetricExtentDirection)
Dim extrude1 As ExtrudeFeature
Set extrude1 = partDef.Features.ExtrudeFeatures.Add(extrudeDef)
' Change the work surface to not be transparent.
Dim surf As WorkSurface
Set surf = extrude1.SurfaceBodies.Item(1).Parent
surf.Translucent = False
Set prof = sketch2.Profiles.AddForSurface(equationCurve)
Call extrudeDef.SetDistanceExtent(9, kPositiveExtentDirection)
Dim extrude2 As ExtrudeFeature
Set extrude2 = partDef.Features.ExtrudeFeatures.Add(extrudeDef)
' Create a new sketch and an intersection curve.
Dim interSketch As sketch3D
Set interSketch = partDef.Sketches3D.Add
Call interSketch.IntersectionCurves.Add(extrude1.SurfaceBodies.Item(1), extrude2.SurfaceBodies.Item(1))
End Sub
Ravi Kumar MB,
HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: [email protected]
