Dimension between two points
Hi, I am having trouble setting the dimension between two specific points. I am able to choose the first, but not  the second point, and instead i have to choose the whole line, making the dimension have wrong values. Below I have attached my inventor file, as well as a pic of how I would like the dimensions to look. I am having trouble with th "120mm" dimension and I am not able to choose the corner in the top right.
Thanks for any helpfull replies!
Greetings,
Erika
rdyson
I'm guessing that this is what you're trying to accomplish. You're problem is probably caused by choosing a drafted surface for your sketch plane. You would be much better served to have modeled the part symetrically about the origin planes and used them for your sketch planes, whenever possible.
PDSU 2016
Hi, I'm unfortunately not able to open the file that you have attached, so I cannot say if what you are suggesting is right or not.
Erika
I recieve the following message when trying to open the file: Error in reading RSe stream. Can you please clarify for me what this means?
Erika
JDMather
That error message is an indication that the file was saved in a later version (2015) than you have (2014).
You should always indicate in your problem description when you are not using the latest version.
Check the attached file.
Note: I suspect you don't really really intend for this sketch to be on an angled workplane.
JDMather
Edit Sketch1 and notice in the lower right corner of the screen that it indicates you still need two dimensions because your sketch is "floating" in space.
Use the Projectec Origin Center Point (green dot in image) to anchor your sketch.
Simply drag that corner of the sketch to snap to the dot.
All of your sketches should say Fully Constrained in the lower right corner of the screen and you should see a "thumbtack" in the browser and your sketch should change to a "dark" color.
