VBA & Macro Issue
- Mute
- Permalink
- Report
I know this has been discussed previously for other versions of Inventor but i've tried all fixes shown on other posts that i can find (see below) but i have an issue whereby when i try to open the VBA editor or macro from the ribbon bar they act like dead links. (IE they just don't do anything, no errors shown). I'm running Inventor 2017 on Windows 10 Pro.
It is really important i get this working as I have a project deadline but need to run some scripts i have on the assemble prior to issuing. Unless you fine folk know of a way to rotate components around a axis to a specific degree? This would get me out of a jam i could solve this issue at my leisure. Currently i can only do this using free rotate in assembly but for my deployment this is not accurate enough.
I rarely need to used scripts and as such i have not tried to see if the VBA & Macro ribbon bars button had worked previous. I assume not as it still doesn't work after the reinstall
I've double checked and VBA editors are working in other programs that are install (EG Office)
Attempted fixes
- Repair inventor install
- Uninstall inventor and reinstall
- disable UAC in Windows
- Uninstalled Vba7.msi manually and then reinstalled from the install files
- Checked Default.ivb is present and Inventor is pointing to it (currently in default location)
- Replaced Default.ivb in case my copy was corrupted.
