Message 1 of 32
Using the Loft feature to create irregular pyramids on a cylindrical surface
I'm trying to recreate this following object:
What I'm doing is a simple revolution as the base, I create an offset vertical plane, draw an irregular polygon and a point on it, project this polygon onto the cylindrical face as a 3D sketch and then use Loft from the projected polygon to the point on the offset plane.
I've had mixed results. While I've been able to create some pyramids I am getting the most varied of errors while using Loft, "not a closed loop", "creating non manifold geometry", "the attempted operation did not produce a meaningful result" or simply "could not build this Loft".
Is there a better way of going about this?
Thanks in advance!
