Inventor Forum
Using a iLogic rule to run local update
4 REPLIES 4
2494 Views, 4 Replies
Good Morning,
I have a multifunction rule to create different size structure base on the size of a Cyclone, it appears to work, but I have to Regenerate the Rule and do a Local Update. Is there any way I can add a variable in my rule to do this automatically?
NeilJ
4 REPLIES 4
Curtis_Waguespack
Hi Neil_j51,
I think this should do it:
'update all
iLogicVb.UpdateWhenDone = True
related link:
http://inventortrenches.blogspot.com/2011/05/ilogic-update-and-zoom-all-after-size.html
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Thank You for your reply. I have tried the statement and it did help some, but I still have to right click on the rule to say regenerate to fix the model. Is there another statement I can add
AhmetSevik
Maybe cod must run inclusive for subassmbley and sub part too. I don't know exist or not.
I have similar issue for me and i saw that if i make deactive (Supress) someof subassembly with ilogic code, then this suppress subassemblies doesn't make locak update. I open seperatly and i done local update on it, then error was gone.
Cosmin_V
Be sure this is not selected!
