hi experts
Is there any options to link thread dimension in *.stp file?
The correct is thread(M) instead of diameter(D)
I know this is caused by no relationship, so ,does anyone have a solution?
Thanks!!
hi experts
Thanks!!
Solved by johnsonshiue. Go to Solution.
We usually just include a 2d PDF of the .idw file with tolerances, inspection dimensions, and hole notes with our STP exports.
Other options:
Model the thread.
Use a 3D Annotation in the part file and export a STEP 242 file?
Steve Walton
Other options:
Model the thread.
Steve Walton
If @swalton answer isn't what you were looking for please be a bit more specific about what exactly you are trying to accomplish or let us know the specific problem you are encountering and I'm sure some solution can be provided..
Hi! Another option is to install the free Feature Recognition Add-In for subscribers.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win64
Many thanks!
Many thanks!
Above experts
This is a stp file, and i want to dimension a thread hole
like this
is there any method to do?
thanks
Above experts
like this
thanks
Hi Johnson Shiue
when open stp file, using this tool it can recogize features
and save the data to import into idw.
Will it show the dimensioning?
thanks
Hi Johnson Shiue
thanks
but it can only recognize hole features, instead of thread holes.
Thus should i first recognize hole features, and edit as thread feature?
If the quantity is large, do i need to edit one by one manually?
thank you
thank you
Hi! Indeed, some manual steps are needed. Feature Recognition does not recognize thread. The thread info isn't included in the STEP file anyway.
Many thanks!
Many thanks!
@francischen wrote:If the quantity is large, do i need to edit one by one manually?
If the Holes form some sort of Pattern(s) you can recognize as Pattern(s) and then you only have to edit the seed of the pattern. Otherwise you will have to edit each individually.
Thank you all above
I have found the answer!
Thank you all above
