how to copy fx user parameter from one file to multiple file.
khadeerkruthi
khadeerkruthi
hi team,
this is regards how to copy the fx user parameter from one file to multiple files including .ipt, .iam, .idw
bhavik4244
@khadeerkruthi
A quick way is to do it by exporting parameters as XML file, here you can choose "All parameters" or "key Parameters" while exporting, and then in the same way you can import xml file to desired part or an assembly. It's recommended to export the key parameres only else it would create a mess!
Options
Another way to do this is by iLogic,
Cheers!
Bhavik Suthar
