I'm sorry I'm not getting it...
1. In Part1 I have a Sketch with various points.
2. I create a work point on the "first" point of the Sketch
3. I create a Sketch Driven pattern with point work features
(I'm not sure if steps 2 and 3 are needed and this is what you were mentioning but I use these patterns latter on at the assembly level).
4. In Part 2 I derive the Sketch from Part 1 and I derived all the work points too
5. In my case I created a cut extrusion in Part 2
6. Pattern this cut extrusion using the Sketch from Part 1 and work point. No success.
What would I be missing?
I can create a Sketch in Part 1, derive it in Part 2 then edit it from Part 2 and add points there on the points already existing. This I know works, but I would like to use this Pattern multiple times and would like to avoid duplicating the process.
Thanks again!
