Use iLogic to add faces containing a certain color to a list
Message 1 of 1
I've been presented with the idea of somehow accounting for paint in a BOM.  Sounded easy enough, but turns out not so much.  I have a part in which certain faces are selected and set to a certain color (Yellow).  Is there a way, using ilogic, to loop through all the faces to a part body and add them to a list if they are a certain color?  After that I intend to loop through that list and tally up the total area in the same rule.
Basically, something like this:
Dim oPartCompDef As PartComponentDefinition
oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oList As New ArrayList
For Each oFace In oPartCompDef.Faces
If oFace.Color = "Yellow" Then
oList.Add(oFace.Name)
End If
Next
Replies (0)
