Grounding first part placed in assembly
Message 1 of 10
Hi All
I am using Inventor 2013. I want to dissable the automatic grounding of first placed part in an assembly. I am sure there used to be an option in the Assembly Tab of Application Options, but I cannot find it anywhere. Can anyone please advise?
Replies (9)
Message 2 of 10
-niels-
According to the "what's new" documents, that function was introduced in IV2014.
Where do you remember seeing it?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 10
That is a good point, I may just be kidding myself, because everything I Google on shows the option. I have it in my head that manipulating this function is available prior to 2014? I may be wrong? If it is, I would like to know how?
Message 4 of 10
-niels-
Well, you could check the registry if there's a key similar to this one:
For 2013 it would be "RegistryVersion17.0".
I wouldn't get my hopes up though...
Niels van der Veer
The Netherlands
Message 5 of 10
mslosar
I have to say, i'd thought i'd seen that command prior to 2014, too. Just ran through '13 and couldn't find it.
The registry key isn't in '13. I did a search for the word ground in the registry as well - it's not under USER or LOCAL MACHINE either. Hard to believe this wasn't asked for plenty prior to '14.
Message 6 of 10
blair
I thought it was introduced in 2014 and not earlier. I do agree it should have been implemented much earlier.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 7 of 10
JDMather
In my opinion it is one of the poorest decisions made by Autodesk to not leave it the default place and ground at origin for first component placed in an assembly.
Fortunately for trained users it is a simple right click, but I see too many untrained users....
Message 8 of 10
blair
Sometimes the part you start with isn't in the proper orientation for the assembly.
Delta Tau Chi ΔΤΧ
Message 9 of 10
JDMather
Sometimes.  Then I simply unground.  99% of the time the first part that I place into an assembly I want placed and grounded at the origin.
Message 10 of 10
All - tend to agree with all comments. Grounding is a problem with less experienced users, they think items that are grounded are constrained. Thanks for your replys, i guess i am going to have to wait until we migrate to 2014.
