Use construction lines for another (new) sketch
Message 1 of 9
Can any one help me for solution one troubleshooting with Inventor 2012?
I opened sketch and drawn construction lines in it, after that I opened new sketch and tried to use construction lines from a first sketch.
In addition, I share the first sketch too, but this does help.
How can I do it?
Replies (8)
Message 2 of 9
JDMather
In the new sketch use the Project Geometry command to project the geometry from the first sketch into the second sketch.
Message 3 of 9
Thank you for the answer, but this option doesn't work.
Message 4 of 9
JDMather
It has worked for me for 15 yrs.
Attach your *.ipt file here and end all doubt.
Message 5 of 9
I try to correct my explanation, the sketch with construction line, I didn't convert it to object or feature.
Possible in this reason, it doesn't work properly?
Message 6 of 9
JDMather
No, that is not the reason.
With your actual *.ipt file - I will be able to find the reason without any explanation in written words.
Message 7 of 9
JDMather
What happens if you -
1. Reboot your computer.
2. Start a new part file.
3. Start a sketch and create a construction line.
4. Exit first sketch and start a second sketch.  Select Project Geometry and pick the construction line from the first sketch?
Have you installed all Service Packs and Updates for your version of Inventor?
That is a very old release - did it used to work properly?
What happens if you go to Tools>Application Options>Hardware tab and set to Software Graphics?
What version of Windows OS are you running?
Message 8 of 9
Ray_Feiler
I have access to Inventor 2012; just tried to project a construction line from one sketch on to another and it worked. It projects as a construction line in the new sketch but you change it after you project it.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 9 of 9
Curtis_Waguespack
Hi StanislavSpektor,
Here's a quick video of how it should work.
I hope this helps.
Curtis
A link to the video in case it does not play correctly here.
http://autode.sk/21cnqit
