undo error
undo error
undo error
Hi Experts
I cant open my inventor because of the error shown below. Deleted all possible files from local/temp. But cant make more room there.
How can i fix this ?  Do I need to open inventor to make any changes to this ?
leowarren34
Hi @Anonymous,
How much space do you have left on your computer?
If you have multiple drives on your computer it may be worth moving the undo folder so somewhere with more space,
alternatively, you can reduce the undo file size to within the space available,
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Hi Leo
To make such changes, I need to open Inventor. I cant do that now, thats the issue.
leowarren34
Hi @Anonymous,
Firstly make sure you have emptied your recycling bin since it can occupy quite a bit of space. Then where possible create some space (4GB since that's your undo file size) on the C drive and create a new folder.
Set the Undo folder to the location of the new folder.
Leo Warren
Done and it worked
