Hello all
First post to the forum. Can anyone help me out?
I have made a sheet metal model, where all of a sudden I can't seem to make sheet metal metal cuts or 3D model extrusion cuts for a button panel. Also other sheet metal and 3D features are unavailable.
The file is attached
Solved by mdavis22569. Go to Solution.
@Anonymous welcome
Can you help us a little ..what version of Inventor are you using?
Hi @Anonymous
So I deleted the flat pattern ... you'll see you had an issue with a sketch in it
I then was able to cut everything ... and create a new flat patter
