We use Inventor 2017, Win 7 64-bit, Excel 2016
We have a problem with Content Center threaded parts (nuts, screws etc.). We get following error message when we insert parts:
"Unable to successfully update the member part file. Problem occurred when setting thread data"
Parts can be inserted but the thread is wrong. I tried to fix the problem by replacing our customized Excel spreadsheet Thread.xls by original Thread.xls file, and that didn't help. I also tried to use Inventor Reset Utility to reset the local environment for a Windows User Account (Inventor), and that didn't help either.
Any suggestions how to fix this?
/Amir
First have you applied all the latest service packs/fixes for Inventor 2017. Many were experiencing content center issues and the latest fix has seemed to fixed those issues. I would start there. I've all seen over the years odd things regarding content center and thread information. Years ago I ran into a similar issue and I don't remember how I got passed it. But I would check to make sure all the thread data is in the correct format and meets what's in the thread excel spreadsheet.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Very strange things are happening.
When I changed project file to default.ipj I was able to insert parts with no problem. Then I changed to our project file "company".ipj and still no problems. And when I restarted Inventor and tried to insert same parts with "company".ipj errors occur.
I don't get it...
It seems to me that there is some kind of bug.
Hi Amir,
If it works when using the Default project and not your Company project, then the two projects are pointing to different content.
Edit your projects and compare the location of the content in the "Folder Options" section.
Jon.
Hi! Your issue may or may not be the same as this thread. Could you provide an example exhibiting the behavior?
Many thanks!
Hi! Please send me an example (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
In our case the problem was caused by our CAD supplier because they migrated old Design Data (2015 version into 2017 version) when they upgrated our Inventor from 2015 to 2017. When they installed latest version of Design Data, which was 2017, the problem was solved. Regards /Amir
Hi! A few things to check. Do you have thread.xls in the \Design Data\ folder? Without it, any thread related workflow (threaded hole, hole notes, thread) will not work. Do you have Excel.exe installed? What Inventor version are you running?
Many thanks!
Hi
same problem again!
It must be something with Win 10 1903 and 2019.4 update to do because I didnt have that problem before I updated.
Anyone that have a clue how to fix it?
Hi! I am not sure if your issue is the same as this one. Please install 2019.4 update followed by 2019.4.2 update. Make sure all critical Windows updates are installed. If possible, please share an example exhibiting the behavior.
Many thanks!
I have newest Win 10 uppdates, I installed Inventor 2019.04.02 and the problem remains, partially.
And what do I mean by partially 🙂
Well I tested to insert a threaded standard part from Content Center into a new assembly first time and it worked. Then I tested to insert the same part from CC to a assembly that I had problems with threads yesterday where I saw the issue for the "first" time, and the same problem happened. Then I tested again to insert another part into a new assembly and problem remained. Went back to my existing assembly and tried again with other threaded parts, no different. THEN I started new assembly AGAIN and then it WORKED! I used same part that didn´t work before. So to solve my problem with my existing assembly I copied that part into the assembly and no error message showed.
These issues when it works sometimes and sometimes it doesn´t are the funnies ones 🙂
Hi! Another place to check would be your Project file. Make sure the Design Data folder and Content Center folder are set up correctly.
Many thanks!
Hi!
Thanks for trying to help.
It is nothing wrong with the project file and Design Data and Content Center folders because everything worked just fine BEFORE Win 1903 and Inventor 2019.4 update.
We have not changed any settings since we updated Inventor version from 2017 to 2019, update done in november 2018, so since then no problems with Content Center, until now...
I wonder if Autodesk have got reports from other users about this issue because this problem seems to occur from time to time? As you can read in this thread I had same problem with 2017 version, and other users also had same/similar problems with standard parts threads from Content Center.
Thank you
/Amir
Hi Amir,
Inventor 2019.4 should address Windows 10 build 1903 issues. Please take a look at the following thread and install the appropriate updates.
For 2019, .4 update should address the problem. Please double-check Help -> About and see if 2019.4 is indeed installed. If not, please install 2019.4 followed by 2019.4.2 update.
Many thanks!
