Unable to modify dimensions
Yashasvi23481
Message 1 of 13
Yashasvi23481
 I was in sketch mode and all of sudden I cudnt modify dimensions :(. Is there any key which locks the dimensions. I closed the part file and Inventor and reopened. still not effect. I even tried doing via parameters but it wudnt change. I am suspecting I have pressed a function key. for example, I wanted to change from 99 by default to 75 mm for locating hole, its doesn't change. Is there anything called dimension lock which I activated by mistake ?
Its not the only dimension I tried changing other dimensions as well in same sketch but same effect. I even deleted the sketch altogether and restarted new sketch but dim wud go back to original 99. I guess inventor is in weekend mode.
Let me know. Will check on Monday.
Yash
Replies (12)
Message 2 of 13
Marco.Takx
Hi @Yashasvi23481,
Is it have to do something with this?
Inventor, Can't edit dimensions in a sketch
Witch version incl. update of Inventor are you using?
If not can you share your part.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 13
ratneshmalik1990
may be that dimension linked to some other thing.
Autodesk Inventor Certified Professional | Mechanical Design Engineer
Message 4 of 13
TheCADWhisperer
Attach your file here.
Message 5 of 13
Cadmanto
Is below your issue?  Patterned dimensions?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 13
TheCADWhisperer
@Yashasvi23481 wrote:
by default
My guess is Reference dimension.
Message 7 of 13
Yashasvi23481
Hi All,
     Thank you for help. Its neither pattern nor other issue. I am attaching word file with screenshot. And also part. when I try to override it comes as message saying its consumed by sketch. and I cant change in parameters too.
I am also attaching my sketch settings in application option in case there is something missing. I created the body of the car in normal way only when I implemented new sketch this issue has come up, so I wud assume application option has nothing to do. I am creating recess hole for bolt.
Yash
Message 8 of 13
ToddHarris7556
d72 edits just fine on my machine.
Double-click, change 100mm to 130mm, update part, hole moves.
It also works via editing in the Parameter page.
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
Message 9 of 13
Yashasvi23481
Hi Todd,
   Must be something at my end. I tried accepting dimension and then type in d72=whatever dim I wanted in dim box, it updates. But earlier, I cud just double click and change now it doesn't. even in holes, I have to type = before dimension or else it doesn't change. So, I need to modify dimension when I create.
Yash
Message 10 of 13
Yashasvi23481
Hi All,
    Just figured out what went wrong...My num lock was on/off and I was entering numeric value from number pad so didn't register/update. I entered the dim using keys above alphabet , that's when I realised my num lock was on.
    However, now when I try to select a plane to sketch, it doesn't show plane straight in front of me like looking at plane its isometric even after I select the face to sketch.
Yash
Message 11 of 13
johnsonshiue
Hi! The option to control the behavior can be found at Tools -> Application Options -> Sketch -> "Look at." One is for  part and one is for assembly.
Many thanks!
Software Test Engineer
Message 12 of 13
Yashasvi23481
Hi Johnson,
      it works. Thanks a ton ! Yesterday it was playing up as it was unticked.
Yash
Message 13 of 13
Yashasvi23481
Hi Everyone,
    Although original issue was fixed by myself as num lock was pressed. But thank you all for putting your time in. I have learnt something new with the solutions you provided.
Yash
