unable to create proper flat pattern
kanchha87
Message 1 of 8
kanchha87
Can anyone solve my issue regarding not being able to generate the proper flat pattern? I have attached the part and drawing files. I appreciate the help. Thank you.
Replies (7)
Message 2 of 8
ampster40
Both flies open with Inventor 2023 with no errors present and everything appears as I'd expect other than a 90 degree bend dim showing the actual bend in the print appears to be missing but could also be considered OK by some companies depending on standards as well as a missing hole callout.
Sheet metal defaults have been set correctly for 16GA CRS.
Without digging any deeper, everything appears ok up front.  What is the problem?
Message 3 of 8
kacper.suchomski
Everything works for me too. What's the problem?
Kacper Suchomski
Message 4 of 8
johnsonshiue
Hi! Please be more specific on the failure. Is it about Flat Pattern not oriented desirably? What is the failure? Please make sure 2023.4.1 update is installed (you are still on 2023 RTM build).
Many thanks!
Software Test Engineer
Message 5 of 8
kanchha87
Hi there!
Thank you for reaching out. The failure we're encountering pertains to the orientation of the Flat Pattern, which is not aligning as intended. It seems to be a glitch related to the orientation settings. I'll double-check to ensure that the 2023.4.1 update is installed, as you mentioned.
Thanks for your prompt response!
Message 6 of 8
Frederick_Law
Edit and redefine the flat:
Message 7 of 8
kanchha87
thank you for your invaluable assistance in resolving this matter. Your efforts have not gone unnoticed and are deeply appreciated.
Message 8 of 8
Frederick_Law
You can also rotate it in drawing:
