I am not able to change the thickness (weight) of the Dimension Lines in Sketch mode. When I open Styles Editor in with a IPT open, I only get
Lightning and Text as options.
I already changed Style Library to Read-Write in Projects, but no success.
I only want to change the appearance of the line width in the viewport, nothing more. Changing of Annotation Scale in Options only changes the Point and Textsizes, but not the line thickness.
The Line is so thin, it appears nearly as dotted. Also the smoothness of all of the lines is quite badly.
I am working on Windows 10, NVIDIA GTX770 GFX
Inventor 2016
Best regards,
Michael
You can change sketch line weights in tools..document settings..sketch tab
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-58DD9A89-84C7-48F3-8E4E-0303E755B10F
Might be graphics card related...
Have you updated your graphics card to the latest version?
What settings do you have for tools..application options..hardware tab? (should be quality and software graphics off)
Change your Application Options/Hardware setting to Performance. Exit Inventor and restart it. Is it better? Repeat process for Conservative setting.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Is it possible to post your part and have someone else review the sketched dimensions on their machine to compare what they see?
Edit: I duplicated your sketch based on your image and this is what I see
(But I don't have that video card and Windows 10 and my INventor 2016 is at R3).
Mark Lancaster
Sure,
here is a simple sketch as ipt and the corresponding screenshot with 1920x1200x32bit resolution.
Thank you!
Here's what I'm seeing from your part (resolution 1900x1080):
Mark Lancaster
Looks much cleaner, but the dimension lines are also thin.
I don´t know whats the matter, maybe Windows 10?
Regards
Under tools/application options/color, what color scheme are you using? Presentation? DId you ever modify these settings using the color scheme editor?
Mark Lancaster
How do your models look too? poor antialiasing there too?
For the past 3 years I've had antialiasing issues on newly installed Inventor versions compared to the previous one.. I've had to use the Inventor reset utlity each year and that takes care of it..
What about your resolution? Is it the native resolution for your monitor? (that can make a huge difference if you are using the wrong resolution/ratio)
and here.. looks fine on my computer..
Just for giggles...adjust your Annotation Scale to 1.5
Appliation Options --> General Tab
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
I also tried to change the Nvidia AA Settings like described here:
But no change in behaviour unfortunately...
