Tutorial Gallery error Autodesk Inventor 2020
Hi there,
I am getting the following error when I try to open the Autodesk Inventor 2020
tutorial gallery.
Cannot GET /guided-tutorial-plugin/v3/gallery
I have just installed Autodesk Inventor.
Replies (33)
j.palmeL29YX
Have you installed the 2020.3 Update?
Jürgen Palme
Yes, I have.
After I installed it, the Tutorial Gallery no longer shows up in Autodesk, I attached an image. Capture.PNG
j.palmeL29YX
Maybe it is only hidden? Pick the drop down arrow ... (see attached image).
HTH
Jürgen Palme
mdavis22569
What happens if you unplug from the Internet and start using them?
Also, make sure you have access to the following:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
(Yes it says AutoCAD but it could be you're blocked to getting access)
Mike Davis
johnsonshiue
Hi! Go to Tools -> Add-Ins -> make sure "Interactive Tutorial" Add-In is loaded.
Many thanks!
Software Test Engineer
I tried that and it didn't work, here is what happened:
After I updated to 2020.3 version, I can no longer find the tutorial gallery in the top bar. I tried unplugging the internet and nothing changed
Here is a screenshot:
The tutorial gallery is loaded, but it does not show up in the top bar.
Hi everyone,
Originially I was having problems with the Tutorial Gallery so I installed the 2020.3 update.
Now when I open inventor, the tutorial gallery is missing from the top bar.
I have tried several methods to fix this including unplugging the internet, checking add-ins to see if tutorial gallery is loaded, and none of these methods have worked.
I would appreciate any help please and thank you!
mdavis22569
Did you change / modify yours?
I don't have the User etc under my get started like you're showing
it's like it didn't fully install. I would do a reinstall with the Inventor Reset Utility ... get it back to Out of the Box look
Mike Davis
After using Inventor Reset Utility this is what happens:
Tutorial Gallery is still missing.
mdavis22569
We're a tad close ...
Do you know if the MSI has been installed?
I would review this now
https://forums.autodesk.com/t5/inventor-forum/autodesk-desktop-connect-and-guided-tutorial-plugin/td...
Mike Davis
Yes both of those MSI's are installed, yet it is still not showing up.
mdavis22569
Addin loaded?
Mike Davis
Yes addins are loaded.
When I doubled clicked on each of the MSI's, a message popped up that said
Stopping LWS, and then it automatically closed.
DannyHubbard
Can you try reinstalling the Tutorial Plugin and the Connected Desktop service using the AutodeskDesktopConnect.msi and AutodeskGuidedTutorialPlugin.msi  as mentioned in https://forums.autodesk.com/t5/inventor-forum/autodesk-desktop-connect-and-guided-tutorial-plugin/m-...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
I am still getting the error : access to desktop.connect denied    at startup.
I seem to have identified the issue:
I am getting the following error after unchecking and checking loaded and automatic on adding.
I have desktop connector installed, but I am getting this error. Is there a way to reinstall or fix desktop connect?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
