Inventor Forum
Turn Sketch into a polyline
5 REPLIES 5
1619 Views, 5 Replies
After drawing the sketch and extruding it there are some extra lines that show up in the drawing that should not be there, maybe that problem could be solved if I could turn all the lines that compose the sketch as a polyline or something of the kind, can anyone help? (in the .JPG file you see it circled in red )
Tags (2)
5 REPLIES 5
johnsonshiue
Hi! The edge is there for a reason. It means the face on one side of the edge is different than the other side of the edge. You can hide it by right-clicking it in the drawing view -> uncheck Visibility. In real world, the edge is indeed there. It is just that it is not as apparent as it looks in the drawing view.
Many thanks!
Software Test Engineer
Mark.Lancaster
@Anonymous
Adding to @johnsonshiue information.  When posting and sharing files, always indicate what Inventor versions you're using.  In your case its Inventor 2017 (original release).  You may want to think about updating your version of Inventor...  You have a version that came April 2016..
Mark Lancaster
rhasell
Hi
Its because the part is actually poorly modeled.
Besides not having any dimension or constraints, the line in question is actually an overlapping arc, hens the reason for having to try and clean it up with fillets.
Have a a look at the attached part, if you are able to open it.
Just in case, I attached a screen capture of the preferred profile.
Reg
2025.1.1
Please Accept as a solution / Kudos
Mark.Lancaster
in reply to: rhasell
@Anonymous
In addition to @rhasell information..
Keep your sketches simple..  Looking at your model structure, it looks like you are doing extra work or redoing the same steps over again.  Don't sketch out holes.  Use the actual Inventor functions to make your life much easier..  The method you're using is like putting all your eggs in one basket.  Smiley Very Happy
For example (screenshots since I'm using Inventor 2018 right at the moment)..
Your base or first extrusion..  Granted I don't have all the dimensions but just a quick way of showing an example in how to keep your sketches simple.  But as @rhasell pointed..  Sketches should be properly dimension and constrained.
From there I extrude all the closed profiles in my sketch..
Then I start a new sketch on top and extrude the boss part..
From there I made 3 concentric holes.  Two on the lower base and one through the center.
2018-03-15_21-54-28.jpg  Then added the chamfer to the center hole.
In the end each of us would attack this problem differently but keep your sketches as simple as possible and use the actual modeling functions within Inventor and don't sketch modeling functions.  Let the software do the work and when it comes to the drawing aspect, it will make your job easier.. Smiley Wink
Mark Lancaster
in reply to: Mark.Lancaster
Thank you very much kind sirs, I will be working very hard to improve my modelling skills.
